2000 RPM Vibration
2000 RPM Vibration
I have done the motor mount shim. Replaced the front mount. Does whether its in gear or neutral. Over 2000rpm it will smooth out. Once it idles down to 2000 or I cruise at or under 2000 it vibrates to hell and back. Its not even fun to ride. I did notice the top stabilizer mount has some play in the bushings. I am gonna replace that and the rear mount and see what happens. If that doesn't work then its going to a local indy.
Yes, check the mounts.
What year bike is it ? It could be a more seriousroblem with the crank.
I know you didn't post this forhelecture, but......
It's true. Unless you have a very torquey cam, your usable range starts at. 2200 RPM. Cruising below that is lugging the motor. I have the SE 255 cams which have good torque at a very low range. Even then, 2000 RPM is the bare minimum range for cruising. It sounds like you may be running it at too low an RPM.
Its a 95 Low Rider. I took my friends 97 Low Rider for a ride around the block just to see how his handled and it was a world of difference. No vibration hardly at all. Mine has 44k miles on it. The top mount has me concerned with the amount of play it has. Almost as thought the rubber bushing dry rotted.
I have a 96 fxdl with the exact same symptoms. My fm is good, but rm is questionable. Last nite I jacked it up just enough to take pressure off the mount to see if I noticed a difference when holding it at 1800-2000 rpms. Didnt seem any different, but I rode today and it was almost completely gone!
I'll be replacing the mount.
I have a 96 fxdl with the exact same symptoms. My fm is good, but rm is questionable. Last nite I jacked it up just enough to take pressure off the mount to see if I noticed a difference when holding it at 1800-2000 rpms. Didnt seem any different, but I rode today and it was almost completely gone! I'll be replacing the mount.
Received 4,309 Likes
