oil cooler
Had a Jagg 10 row cooler, just had a rock jump through it this weekend. Made for an exciting ride. If I mount another I will put something like a guard on it to keep that from happening again. I would suggest carrying something to bypass the cooler.
The cooler itself worked fine, I did not have any issues with it at all.
I wanted to add an oil cooler for the longest time till I discovered something.
Recently I have installed an oil temp gauge, I found the motor gets hot so fast at a stop. As soon as I move, even as slow as 5mph, the temp drops significantly. The incoming air is the key to cool off the motor. I wouldn't say the oil cooler doesn't help at all but it will not cool off the motor that much without a cooling fan. If I ever buy a cooler, I will get the Jagg 10 rows with a electric fan like Reindeer did.
Jagg 10 row low mount has been on mine for over a year and when its hot and setting in traffic you set get radiation off the cooler which helps cool the engine.
I changed the worm gear clamps with fuel injection hose clamps the worm gear kept loosen up. causing it to sweat around the clamp area and I hate any sign of a leak.
