2000 Low Rider Headlight Change
Hey guys,
New here and only riding a year. I bought my 2000 Dyna Low Rider last year and have been doing some changes. For one, I cannot stand the look of that headlight visor. I tried to take it off yesterday and found the headlight was mounted into it. Has anyone else removed this? Is there any other option than getting a top mount bracket? Not so sure I like the looks of those either. Then there is the indicator lights that are also connnected into this visor. I saw some riser clamps that I can get to resolve that if that is the only option. I am sure someone here has done this. Any help is appreciated! Thanks
I just did this myself to my 98 FXDL so I can help if needed. I'll give you the steps, if you have any questions ask. Here's how I did it. Remove the tank console, unplug indicator lights, remove the headlamp and unplug it, remove the pins from the plug, once you have the wire out remove brow and indicator lights and headlight bucket. Drill the center of the tree. I went from the bottom up for more clearance and used a 90 degree drill. I picked one up at harbor freight that ran off the air compressor. It was slow and underpowered but it got the job done. I returned it after it was too weak to keep. Once the hole is drilled you just need to mount up a headlight block and headlight and wire it up. Last decision to make is for the indicator lights. I was given a piece of aluminum cut to fit the top tree, I cut and polished it to make it look like the headwinds plate, cut a hole for my indicator lights and bought new ones. When bolted up I didn't like it so I removed it and mounted a sportster chrome top tree trim piece. I drilled two holes in my console for the neutral and oil light and didn't need the rest. It's really not that hard, the hard part is picking a light you like and deciding on your indicator lights. I ended with a 2012 headlight and block. I trimmed the block a couple 8ths of an inch to get it where I wanted it. PM me or post here if you have questions.
I have a pic with the indicator light plate mounted too, but it's hard to see, I removed it before I started swapping the bars.
Are you looking to save money or just buy whatever it is you need?
