Tach wiring help
Tach wiring help
So I bought this tach from a member, PN# 67042-95, and its a 3 wire Orange, Black and Pink.
Orange=Power
Black=Ground
Pink=Signal
I have a 2011 StreetBob and I tried tapping into the Lt Green/Violet wire for signal but all I get is crazy needle bounce.
Am I SOL on this tachometer working? Or can I grab the signal a different way?
Orange=Power
Black=Ground
Pink=Signal
Thanks guys, I grabbed the tach signal from the Serial Data wire at the harness (LtGrn/Vlt) in the diagram. The needle just swings around erratically.
im not 100% positive but on my 06 the signal comes from pin 3 on the ecm. check wiring diagram for your year and see if it the same
nick
nick
Here is a wiring diagram & color codes from a 2010
you need the diagram after the main harness connecter to see where it goes, the serial data line is a communication line. it just lets each of the modules "talk"to each other in easy terms
Just to be clear, was it pin 3 on the ecm? I gotta help a friend hook up a tach on his 2010 street bob, and we are a little stumped.
