SE Comp Installed... Red key light
You can do a quick search here at HDForum and find a thread on how to pull up a code, for me it is easy with a PowerVision tuner. After you pull it up, write it down and clear the code then go ride and see if it comes back, if it does not then you should be good to go - maybe the installer pulled the cables off the battery or something and it is throwing a code for that. If it returns then most likely something is amiss - let us know the code and we might be able to head you the right direction.
Just kidding in post 8. Kill the code and if it does not come back, you are good to go. Be sure both plug wires are pushed all the way on. They may have pulled them when they worked on it. If by chance the wires were loose, the code is set but will quit showing up after a bunch of OK runs.
