kickstand problem
kickstand problem
hey just wondering if anyone else has had a problem installing a new kickstand?this is on my 1994 dyna.i got a new kickstand because the tip was broke off the old one and it was wicked hard to find.is there any certain trick to putting one on?i did exactly reverse order of removal but it wont stay up it comes down at least halfway.and the spring that came with it is even a little shorter than the old one.what the hell did I do wrong?
check the frame where the spring hooks in, are there different ring locations? Is the new stand OE or aftermarket, aftermarket may have a different spring hookup location than OE, Finally where the stand slides into the bracket at the frame is it a snug fit, are the bolts tightened up, an aftermarket stand may need to be shimmed. Hope this helps.
karz10
05-21-2017 06:57 AM
