LED Rear Turn Signals Lose Power, Cluster Indicator Stuck On
Here's the setup I have on my 2009 Street Bob:
2-wire LED front turn signals set up to be turn-only
Stock tail light
3-wire LED rear turn signals wired as the factory ones were (run, turn, brake)
Badlands Load Equalizer LE-03A
Here's the problem I'm having:
When I first put the key in and turn to ignition, all the lights turn on and function properly. The headlight comes on, front turn signals do not (as I said, they are turn-only), tail light is on "run", and rear signals are on "run". If I squeeze the brake, the 3 rear lights all light up, and then return to "run". However, if I hit one of the turn signals, it will flash normally until I cancel the signal. When I do that, the light turns off completely, won't light up when I squeeze the brake, and the turn signal indicator on the dash becomes stuck on, but only dimly lit. Same result on both sides. If I turn the key off and then back on, then they all function again until I try the turn signals, then again they turn off completely and the indicator light on the cluster is stuck on and dim.
Any ideas as to what may be causing this to happen?
Stock tail light
Is a TSM plug and play, like a relay? Or do they have to be reset after the install?
I have access to a few other bikes, they are all 2013s: Road King, Street Glide, Ultra Classic. I'm assuming because they all have security that the TSM out of any of those won't work on my bike?
Edit: Just unhooked the Badlands LE and ran the same test with brakes and turn signals. Does the same thing, only with the hyper-flashing signals.
Got a new TSM in the bike, still acts the same. Unplugged the LE, acts the same with fast flashing signals.
Eliminated the STT module, and the indicators on the dash stay dimly lit, front signals work, rear running lights with turn signals work and cancel properly, only the center light lights up for the brake.
So between eliminating each of the 3 modules, it only changes the symptoms but doesn't fix any of them. Where do I look now?
The bike needs to go through an inspection before I can start riding it, and it won't pass with the lights as they are so any help would be greatly appreciated.
