Trouble reassembling wiring conectors ??
So my new Outlawz are bolted on wires are run thru bars. I used a dog tag style ball chain to pull the wires thru. That makes it so easy. Just feed the chain in the top shake it around and the chain rolls out the bottom. "But" 3 hours later trying to put the pins back in the plugs. They seem like they clicked in. But 8 pin connector now won't lock together. Male to female. Needs another .125" to go. Now I'm seeing on the left side of bike. 4 out of 8 pins are shorter and move in and out the other 4 are locked all the way in and longer with no movement . I must have 4 of them pushed in up side down. But which ones ? Right side throttle side plug won't lock together either. When I took them a part it showed taking needle nose pliers and pulling the inside of plug so pins became very short. Now it won't move in or out. Then using a paper clip to release wire clips. Wtf.
If you did not bend the pins if they are the flat blade style connector terminals just look at the femal side of the connector and find out which side the spring pArt of the terminal is and make sure you did not flip them over, if that's good then check and make sure you did not pull the too far through past the lock because that will cause the same problem. If they are the round " bullet" terminals make sure they are seated correctly they are very easy to pull too far through and also make sure you have the pin in. The correct location because if you have a pin in a bare hole with a sealed plug on the femal connector it will not let it seat either hope this helps you out. Next time you do any connector work you need to get the release tools it will save the pain and hassle. I use a snapon set of general release tools that work for spefic connectors if that helps at all
Paper clips, jewelers screwdrivers, hair pins, T pins...these are just not made to remove tab lock contacts from electrical connectors, and unless you know exactly how that particular connector body holds the lock tab in place, you cannot modify these to work without doing some damage the connector body. You may get away with it once or twice but Murphy will get the last laugh on you eventually.
The lock in the connector is polymer plastic or nylon or whatever composite material they made that particular connector plug out of...the correct tool is purposely designed to retract the tab on the contact without deforming or damaging the connector lock. Using anything else, even a T pin, is asking for trouble if not now, then later when you are in the boonies some dark night out of cell phone range...Murphy said so.
Your connector body is damaged and those pins will never lock in securely. Get another connector and the correct tool and do it right...or take your chances with Murphy.
Good luck and let us know how it goes.
I had this same exact problem last week while finishing up reassembly of my bike.
When I put the wires back into the plug, the secondary lock (white part that was pulled out with a needle nose) was not seated all the way in the plug body. The wires are now holding it from moving around at all, and it is bottoming out when you try to plug it back in.
I had to take the wires back out, then you will be able to set the secondary lock much deeper in the plug body. Keep pressure on it to hold it fully-seated while reinserting the wires and you should be ready to rock.
Sometimes this can happen if a wire is put into the plug the wrong way, bent, etc. Usually requires disassembly in any case.
