swing arm swap?
swing arm swap?
Anyone done a wing arm swap on a 99-05 dyna? I am thinking about swapping to the newer style swing arm and rear fender to accomodate a larger rear tire. I want to fit a 180 on my 2000 fxdx. Anyone know pivot shaft measurements? What about a newer style bagger swing arm on an older dyna? Anyone done either?
It's been done before so it's not impossible and I think machining would be required but if you are going to the trouble and the goal is a 180 tire than I would look into a swing arm from a XR1200.
I wish HD would come out with an "R" model Dyna and one thing it would have is 17" inch wheels both ends to take advantage of all the sticky tires and an aluminum swing arm.
A quick search and I found this:
My 2004 Harley Dyna Custom Project 2011-12 #22 - YouTube
By the way, 2006 is the new style...99 to 05 are same.
bzzrd2
07-29-2010 10:01 PM
