Is a 5K service DIY?
The bike just got over 5K (around 5200 at the moment) and its time for its service.
The bike is relatively new to me (<1000 miles on my name), so i figured it would be a good idea to change all oils on it, is that unnecessary?
Also, is a 5K service something you can DIY?
Looking at the list, i see there are a lot of checking of things but some things like these are things im not 100% on..
- Clutch adjustment
- Adjusting the belt
- Wheel spokes
Is tha manual you have a Harley published service manual?
The reason I ask is they are usualyy for a specific model year, not covering several years.
Harley shop manuals will tell you everything you need to know to service your bike.
That includes a chart in the back showing what needs to be serviced at what intervals.
It also provides step-by-step instructions that are easy to follow.
All torque values are covered along with tightening patterns for multiple bolt attachments.
Grab a manual for your bike. Look at the upkeep requirements and study the intructions.
Take the book out with you and go to work.
Just ordered it, so we will go from there! thanks for the suggestion!
Id like to add that changing all three holes (oil) is very easy and very inexpensive. $40 dollars should get you synthetic for all three.
The skills required for the work your asking about can be found on youtube and can be done by anyone. Of course the factory service manual is a plus.
As for me, I change all three hole every 5,000 miles just because it's easy and cheap to do.
