Got my bike Dyno'd
Got my bike Dyno'd
Got my bike dyno'd. 2011 FXDWG 96". Just installed Feulings Race Pump, Camplate, Lifters, & Pushrods. torrington bearings. Crane Rocket 574 Easy Start Cams. Came out with 90tq & 80hp. Chart showed a 4th gear run, im not sure what the difference is 4, 5, & 6 gear runs are. Sure I would get better results w/a 2-1 system instead of my samson hellraisers. So far I am pretty happy.
Curve looks pretty good, a/f not so great. In the notes it says baseline?. Numbers would be higher with 5th or 6th gear run. Most accurate run is in the 1:1 gear, 5 speed bike is 5th, 6spd bike 6th. Stock bikes usually make more hp down a gear but the higher gear almost always shows more tq.. You'd have to be pretty new to be doing power pulls on a 6spd bike in 4th.
If you get it done correctly the first time there is no need for a "next tune" unless you alter air or fuel. I had my bike tuned by one of the best in the country over 3 years ago and haven't touched it since other than changing spark plugs.
