Wards Cooling Fans for my Fat Bob
Don't seem to hear a lot about these fans here in the Dyna area although the baggers use them a bunch. I live in the North Texas area and the summer heat is really tough to deal with and the biggest problem is when you are stopped or just going slow, traffic light to traffic light. So I decided on the Wards Fans because they help when it really counts - when there is little to no airflow, plus I have the True Track stabilizers installed which hinders a lot of the oil coolers. Here is what came in the mail in about 4 days after ordering:
I opted for the optional thermostat that can be seen in the upper portion of the above picture. The thermal switch keeps the fans off until CHT reaches ~ 200 degrees then cycles on and off to keep CHT in check.
Everybody likes to talk about how easy they are to install but to do it with a professional look took me a couple of hours. Most of my time was spent deciding how to route the wires and connections so they are mostly out of sight and not touching the cylinder heads. It is not a complicated install, just a little time consuming to make it look nice.
Today I was able to take a short ride to check out the fans. It would probably help when you ride off to flip the switch in the up position to activate the fans! Anyway after my bike had warmed up to about 230 degrees CHT and flipping the switch on, the fans started to go to work. I noticed that it is almost impossible to hear the fans with the engine running but I could carefully place a finger behind the fans and feel the airflow.
For me, the biggest challenge/test would be just idling at a stop. Normally my CHT just climbs and climbs when I come to a stop, but with the Wards fans the CHT just sat there and basically did not move at all - the first stop at 255 degrees and the second stop at 259 degrees. Both times I just sat there for about 3 - 4 minutes, never have I ever seen that before.
To finish up, after turning my engine off in the garage, the fans cycled on and off about 5 times to keep cooling the engine - very nice, so far it is one of the best products I have installed.
If I lived in Vancouver, I would not get them either - there are some downsides to being able to ride year round!
