changing forkoil 2010 fxdwg
no, you drain from the top of the forks... you need to remove them and pour out the oil....
theres a few write ups on this forum... https://www.hdforums.com/forum/dyna-...-new-bike.html
A service manual would be a great help as well...
i like to break the top nut loose in the trees, then remove the lower, flip it over and use and impact on the lower damper bolt (12pt 10mm)... from there you can pump out the oil, new teflon tape, new crush washer, torque lower damper bolt to spec... then you remove the top cap (put a towel around the socket you are using to keep the internals from springing out) flip over and drain the rest, the fill, snug up the top nut, install in tree and torque top nut to spec. If you do not remove the lower damper bolt you will never remove all the old oil and/or crap in the bottom of the lower.
Once I've poured out the oil and let it drain for 15 mins or so, I put 1/2 cup of new fluid in, swill it around, then let that drain for a few mins too.
One tip to get the caps back on more easily:
With the spring out, place the cap on the top of the fork. Rotate the cap whilst occasionally tugging up to find the bite point where the threads just engage, then back off 1/4". Make a mark with a non-permanent marker across the cap and down to the fork. Now when the spring is back in, you line up the marks, push down firmly and rotate the cap that last 1/4" until it bites.
