V&h fp3 w/ stock pipes?
So I just ordered the vance and hines FP3. (got it for $33X.XX).
I have a 2014 FXDB with screaming eagle forward facing air filter. I bought the unit because i am planning on adding big radius pipes and I didn't get the download when installed my air filter.
I want the unit to help my FXDB to run better with the current air filter and stock pipes while i save up for the BR pipes. I hope there is a map for High Flow air filter w/ stock pipes...anyone know if the FP3 has this map available? or will i have to get the pipes sooner?!
anyone with the FP3 or experience with one please chime in.
Thanks
Thanks
Thanks
Thanks
you can download the app from apple store or google play to have a go
By the way .. i have one and it is great!
No stock option on pipes or A/C. All maps are pre set to high flow A/C.
Go with the V&H 3" slip on pipe option and load that map. Run through a tank of gas . Then choose auto tune . It will ask you to pick a map. Pick the map you have been running and flash it to auto tune.
The bike will run rough when you first start it so don't freek out. Once you get going it will smooth out.
Run the auto tune for about a tank or so ( checking the cells to see where you are at). If most of it is green you can flash the map to the ECM and your good to go.
Make sure you have the latest app update and ferm wear. It should automatically update when you pull up the fuelpak app and turn on the bike. Make sure your battery is charged because it can take a few minutes to update.
The slip ons with quite baffles might be closer to stock, but like Dan28 said, load a stock tune and auto tune it. When I asked V&H support about running just slip ons with no breather upgrade they said just run auto tune on the slip on tune and it should be fine. I just installed the SE round intake so my auto tuning will start now.
Also he has a pretty high flowing A/C on it. I think he would be closer starting with the V&H 3" slipon map with quiet baffles.
I was able to copy the stock map into slot 2 and it gave me ability to view and modify it in the demo mode, I'm sure the same can be done with the phone connected to the FP3 allowing auto tune to be used. You're probably right about the slip on working better with his pretty hight flow intake.
brandonbelew
09-14-2011 02:06 PM
