Bassani 1D12R Install
Hi, I finally bought an exhaust. I went the Bassani megaphone 1D12R. Looked hard at the Crossbacks but just couldn't justify the price up here on them.
So maybe a dumb question but I am at work and can't check the box. Would it contain gaskets for the install? I called the dealer and the parts guy says it probably should. I didn't order through them. I'm not so sure though.
If I do need to buy gaskets, what do I need? The bike has only a hair over 500km (310miles). Could I re use the existing?
It's going on a 2013 Wideglide.
Thanks
Thanks
Thanks
Thanks
Short answer.. You should be fine even if you reuse your old ones. Just make sure you are tight and have no leaks.
I would be amazed if they came with gaskets. If you do need them, your local dealer more than likely has them in stock and the pair is going to cost around $15, not a big deal. At just a hair over 300 miles on the bike I doubt you will need them, however. Yes, it is a good idea to replace gaskets when swapping exhaust, but at that kind of mileage I'd be hard pressed to believe you have damage to them, or their crushed to a point of leakage.
Regarding SE gaskets and normal... Don't buy SE gaskets just because they are SE. The SE gaskets are FLAT style and if you don't have flat style pipes, they won't seal right. The stock gaskets are tapered and if you have tapered exhaust you need these; my Bassani are tapered, but I'm not sure if that is the case for all of the pipes they make.
If you do get new gaskets please keep in mind they are a pain in the *** to put in right without damaging them unless you have the proper tool. You can forgo the proper tool by using the right sized bearing press, but if you don't have that, you have to take your sweet *** time with them because they crush easily. My advice is to freeze them in your freezer for several hours before installing them since it makes it easier to push them in without crushing them. Some sort of flat tool and work it around gently.
Well I got it installed on the weekend. Went fairly good. The gaskets are a bitch though. But I think I got it. torqued to proper spec and will re-torque again in a hundred km or so. I took it for a spin, way loud to me. Especially compared to stock. But at least it doesn't sound like my Polaris RZR anymore lol.
I will let it get broke in, but I may consider a quieter baffle down the road.
The other thing I noticed was decel pops. Not really a backfire but "pops" Did some reading today and it seems this is normal. I have the micro tune from fuel moto with the correct map. I am wondering tho if there can be to many pops? Coming from stock I never noticed any, and certainly nothing like it is now. Is this something that I should be concerned with? I'm fairly confident the head pipes aren't leaking, I will confirm this week with some throttle body cleaner. I am not really a big fan of the popping, or at least as much as there is there now. Hoping I can at least figure out how to take it down a level for pops.
And here is a pic.
And here is a pic.
