Front wheel bearings
I have a newer wide glide hub that I'm using for my fat bob conversion. The dealer told me for the 25mm bearings the part number is 9276. When I search for it, the part number 9276A pulls up instead. Is there a difference in these bearings? Need to know since next week I'm ordering all the parts so when I get back from my trip to England in June I can do the swap. Also putting new bearings in the rear as well along with a 16x5 rim laced up to my stock hub.
If you get PN-43851-11A (fits 08'-later FLD, FXDF and FXDWG <-- your hub models without ABS), you will get all the hardware (Front 25mm Bearings and Spacers) you need for the bearing install. The kit is $80. The bearing spacer is needed, otherwise the bearings (right one) will will install to deep and will require a one off axle spacer for the right side while still using the left one to get the proper brake disk to caliper spacing.
