Another tire pressure question
Old 05-24-2014, 08:56 AM
wyotana's Avatar
wyotana
wyotana is offline
Default Another tire pressure question
Hey all,
I know tire pressure has been beaten to death. But would it be better to run the pressure recommended on the sidewall of the tires (42 PSI) or in the manual (30 and 35 PSI).
Thanks!
Old 05-24-2014, 09:15 AM
modular's Avatar
modular
modular is offline
I never understood why folks think the pressure listed on the sidewall of a tire is the recommended pressure. That is the MAX pressure the tire is rated for. You should use the front and rear pressures listed either in the manual or the VIN decal on the frame and start from there to your riding style and preference.
Old 05-24-2014, 09:23 AM
wyotana's Avatar
wyotana
wyotana is offline
That's what I figured, I just wanted to double check so I wasn't on under inflated tires
Old 05-24-2014, 09:33 AM
JaronB's Avatar
JaronB
JaronB is offline
I run what's in the manual plus 2 PSI. My first rear I got 11k miles out of a rear and my current rear is at 9k with 95 percent city and heavy throttle (I just can't stop...lol!) and I can probably get another 1k out of it. Fronts I haven't kept one long enough because I switched to a 21" and changed the 21 tire earlier than expected due to a bad tire and cupping. Running the +2 PSI is just enough the bike feels lighter and still maintains good tread wear.
edson443 (09-06-2020)
Old 05-24-2014, 11:31 AM
Jonesee's Avatar
Jonesee
Jonesee is offline
Run the manual pressure.
If you ride 2 up, add a couple of pounds in the rear.
As already stated, the sidewall is the loaded maximum rated PSI for tire.
Old 05-24-2014, 11:40 AM
Von_Zipper's Avatar
Von_Zipper
Von_Zipper is offline
Check the tire manufacturer website for correct pressure for you bike, you should not use the pressure in bike manual.
Old 05-24-2014, 12:02 PM
John_K's Avatar
John_K
John_K is offline
+1 agree on this approach
Let the Great Debate begin!
Old 05-24-2014, 12:20 PM
ntraindavefl's Avatar
ntraindavefl
ntraindavefl is offline
+2 on that.
Old 05-24-2014, 12:42 PM
Kevin714's Avatar
Kevin714
Kevin714 is offline
Received 1,801 Likes on 758 Posts
My bike came with the stock 150/80/16, I'm running a 180/55/18.
I keep my rear tire around 32 PSI. Front around 30.
Old 05-24-2014, 12:55 PM
JaronB's Avatar
JaronB
JaronB is offline
I did that for my Avon and they recommend max pressure. That's a no go!! It feels like you have a rock for a front tire. I split the difference and it's nice and I get good tire wear still.
Quick Reply: Another tire pressure question
