Forward control extensions
Does anyone know if there are extensions available for a '14 Super Glide? I have HD forwards, but I would like to have them extended a couple of more inches if it can be done. I've seen the ones Kury has but they wont fit the Super Glide.
Here's a link to the Kury's:
http://www.kuryakyn.com/Products/230/3-Extension-Kit
i have part #9049 on an 07 superglide... the frames exactly the same as your 2014... It may take some finessing to get your brake linkage rod to clear your exhaust if your running stock pipes... other than that i see no problems as long as your running stock harley forward controls already
taken from the link you posted >
9049 Fits: '03-'08 FXDWG, & any Dyna Models using H-D Forward Controls (P/N 49080-03 or 49080-06) (ea)
Note: P/N 9049 will also fit ’08-UP FXDF, ’09-UP FXDFSE, or ’10-UP FXDWG if stock exhaust has been removed & replaced with a staggered dual system.
