Bike doesn't track straight and level?
2000 Low Rider when I let go of the bars the bike immediately starts to roll to the left. Nothing dramatic but within a couple seconds it's in the other lane. My Sportster would track straight and level so well I could have a smoke and a coffee while cruising the slab handsfree, I could change lanes with a slight weight shift. Is this normal for the BTs? Is the big primary that heavy it unbalances the bike? or is this a rear axle alignment issue? or is the vertical alignment out? How's your Dyna track? Any suggestions?
Check the rear wheel is aligned correctly in the rear forks (swing arm). I've had them come back from the dealer being 1/4" out from having the rear wheel off. There is a small hole in the front of the axle to align from. Then check the vertical alignment. Usually a spirit level reading on each disc is a good guide to see if the top adjuster needs attention..
Swingarm is covered with chrome trim so i can't see any reference hole, no problem...just measured to the pivot bolt. Bike tracks much better but was still rolling a bit. Another turn of the adjuster pretty much solved that. Was out 4 complete turns of the screw. Whoever replaced the wheel obviously should not be working on bikes. My fault though, I assumed it was good and just counted turns and put it back when I replaced the tire a week ago,should have taken the extra ten minutes to check it properly. More work needs to be done soon and I'll take the opportunity to check the vertical alignment then. For now the bike is rideable and it's really growing on me. This animal is a different breed from my dearly departed Sportster for sure.
