Nube FXDX owner long time XL owner cam tentioner question
Just bought a 2000 FXDX 16000 mi from the original owner. Older guy 68 bike is like new always serviced. I'm used to my bulletproof 1200 sporty and am concerned about this tentioner problem. I have a letter from harley in the paperwork that says the cam bearings could be a problem too. I do all my own work and am thinking about pulling the cam plate cover to check the shoe condition. Is this a priority at this time or can I wait a couple months till the summer is over to pull it apart? I ride year round and have no intentions of getting rid of the sporty
I read the thread of the guy in Honduras that had his **** the bed but that was like 60,000 mi or something
Thanks
Thanks
Thanks
Thanks
It only takes 30 minutes to check them, you will only lose about 2-4 oz of oil and I reused my gasket, mine went at 24k and my friends 2001 fxdx went at 22k, give yourself peace of mind and check them, when they go it can get very expensive
seems the newer bikes lasts longer, my friends 05 went at 55k, and another with a touring were changed at 65k
If it'll give you peace of mind, pop the cover off and look its real easy to do. I think at 16k your still safe.
You may have updated bearings in the support plate already. I think they started in late 99 with the full roller bearing on the rear cam. But your inner bearings are probably still the caged needle bearing whereas the full compliment needle bearing is what you want.
The job isn't too hard, I did it myself with the help of the HD manual. Cost less then 300 for all the parts too. I save 100 bucks cause I had access to a bearing puller/putter back in tool.
My 99 had 34K and the tensioner shoes were starting to show appreciable wear.
Good luck
Good luck
Cam bearings CAN be a problem. Replacing them (outer and inner, 4 bearings total) is not so hard though. (I mean, even I could do it...and I'm an English teacher )
Hey that's me! ...and yes, it took a lot of miles for the tensioner to wear. However, you can never be too sure! I'd say you check 'em every time you change your oil, just to keep track of the wear pattern.
