2013 street bob converting from forwards to mids questions.
I just bought a used 2013 street bob with factory forward controls on it. It was a special order originally with the hard candy custom paint and forward controls. I hate the forward controls and want to go back to mids, there is no hole in my outer primary.
I searched on this as much as I could, but didn't find exactly what I'm looking for.
So my question is, what parts do I need to do to do this conversion? I know I need the peg mounts, shorter shift and brake rods and I need an outer primary with a hole in it. I think I also need the shift shaft itself and maybe some bushings or something for the inner primary? Is it possible to just drill a hole in my existing primary cover, or do I really need to get one with a hole in it?
If possible a comprehensive list from someone who would know so I can start acquiring parts would be ideal. Anyone with experience doing this swap? What to look out for?
Also I'm totally open to swap someone who wants forwards for their mids.
Thanks in advance everyone!!
EP 50,
Same story. I am in San Jose CA. Would be glad to buy , but also need chrome outer and inner primary.
Please keep me in the loop . Would appreciate any help you can give.
You can directly contact me at rogersachs@comcast.net
Thanks,
Roger
Thanks,
Roger
Ha same ...
I wanted to switch to the new more forward mids and just highway pegs where my forward controls use to be. I went to the stealership and they quoted with parts and labor approx. 2k. ....**** they better **** and suck me for 2k. I'm better off trading my fxdwg for a new streetbob and switching out my current pipes n intake on the new bike.
Ha same ...
Thanks for the reply. Dealer I went to wanted about 2,200 up to 2,400. Unless I can get outer and inner primary reasonably will stay with my reduced reach with heal support. I also put the highway peg that bolts about the highway bar onto the lower frame, just anterior to the mid peg supports. Not near as good mids, but helps a lot..Coming from a V rod, I was not sophisticated or enlighten enough to know about mid pegs. So I ordered forwards. A mistake especially if you are short. Will know for next time( 3-5 years). I Like the new Low Rider with forward mids and dual disc brakes with abs. Was not available when I ordered. I am a wreck.
Roger
Sounds good, but need some further research for the primaries. Any suggestions.
Also does you box include everything for the conversion- shaft, brake rod , etc. In other words all I need is buy 2 primaries and you have everything else period.
thanks,
You are welcome to contact me directly. rogersachs@comcast.net
Roger
