Clutch problems!
Clutch problems!
So I just picked up a new (to me) bike. an 07 super glide with a 110ci built motor. the starter was out so we bump stated it so i could ride it home.
I heard a strange sound when letting the clutch out from a dead stop
I took off the primary cover and found that the clutch basket, or "shell" is cracked. there is a tooth missing from the starter gear, I found that floating around. No other visible damage though.
How do i replace this thing? do i need special tools to get the shell/basket off and replaced?
Thanks!!!
Thanks!!!
Wow you need a new clutch basket! I would hold whoever sold you the bike responsible. Have a full proffesional inspection done to make sure nothing els is messed up! If the starer gear is broken you will need one of those and a new seal for the tranny mainshaft. plus a tool you can make at home to loc the unlock and lock the clutch bolt and compensator sprockets..
You can go the above route (OE replacement) or... the Evolution Industries bullet proof basket setup (bout $700 part#1006-4092)
These get pressed in. It's not uncommon that this will happen w/ a motor that puts out strong HP. Happened to my father in laws build stroker 106.
MaddGhost, If I bought it from a dealer i would definitely be down there causing a scene. But i bought it from a private party. "as is" as they say.. haha.
Wow $700?!? That definitely is out of my budget. Is there anyway to replace just the aluminum part that's cracked? or do i need the entire setup with the gears and everything?
Thanks!
Thanks!
Basket has nothing to do with the chain, but since you have the outer primary off and the basket out this would be the time since the inner primary will also need to be off when you the chain conversion.
...if your stock is cracked I'd look into getting one stronger than the stock one especially since you ride it hard and it's got some work done to the 110 (would suck and cost you double if it happened again).
I have learned that sometimes if you tend to go cheaper it will cost you more in the long run.
Thanks!
Thanks!
Thanks!
Thanks!
