1k service and oil change advice
So the time is here for the first oil change.
I was going to get it done at the stealership but they want something around $400 for the 1k service so I figure I'm just going to go at it myself. I'm pretty mechanically savvy.
I know I will need oil and a filter, anything else you guys recommend checking out or changing now? Just over 1k miles.
What oil should I get? Also, just get a standard filter from the dealer?
Thanks.
Thanks.
Thanks.
Thanks.
As for the "kind of oil" you'll get a million different answers: Redline, Amsoil, Amsoil in all three holes, or some guy that came up with a secret formula like Penzoil for the engine, Redline for the trans, and buffalo spit for the primary...you're better off just using the search feature in this forum and reading the endless discussions yourself.
As for the filter, get one from the dealer. I used to run car filters on my bike (Luberfiner 2835 or equivalents) but now that I have new oil pump I've [painfully] discovered that the shape/size/width of the gasket in the OEM filter is the best fit for your Harley. (I might wanna try K&N for the next time but hey...if it ain't broke, don't fix it)
