Internal wiring. I got lucky
Hopefully someone will get some use out of this and save themselves a lot of time and headache. For those of you that think or hear that you have to cut/splice wires or remove wires from the connectors to get them through the handlebars you may be mistaken. I've recently changed bars and I was able to pull both switch housing wires and one blinker wire through my bars with the connectors on. I did have to cut one blinker wire but hey, I didn't have to mess with removing each wire from the connector or having to cut every wire then solder them back together. Now I only have to solder 3 wires instead of 15 or whatever it is. I highly recommend trying this before you cut or remove anything. By the way, bike was a 2012 FXDC.
georgiabiker
03-19-2008 06:57 PM
