WideGlide Rear Fender and Tank on SuperGlide
Have 05 Superglide that has a WideGlide front end thinking about finishing it and turning it into all WideGlide Have to change tank and rear fender will the same year WideGlide Parts bolt to the Superglide frame ? Will the Tank bolt up to the same tabs and will the fender fit on the same struts. This is a carb version.
Yes the tank and rear fender will bolt up to stock mounts, But in order to make the rear brake light mount up you will need the wide glide chrome fender strut covers as these hold the taillight, also with the wideglide rear fender you will need a longer seat bracket for the passenger seat as the fender mounting tab is 2 inches further back, as for the tank no problems mounting it, just consider the extra expense for the console, speedo ignition switch and relocation of the dummy lights.
daven9113
10-01-2007 06:01 AM
