2013 Wide Glide..is this normal?
I now have around 3000 miles on it since I bought it. It had 2100 when I bought it. It also had exhaust, Arlen Ness Big Sucker, stage1. When I pull out on my street I ease to the end of the street in 1st or 2nd around 1500-1800 rpms and it seems like it has a miss or skip. It runs good over 2000 rpms but I still feel like I can feel a little miss. Also it seems to have a lot of decel pop if I cut the throttle in 4th or lower and the hotter it gets the worse it gets.
Cutting out and/or missing is definitely not normal. Decel popping is. With less restrictive pipes, its just more noticeable. Installing a tuner can help lessen or eliminate decel popping, and may help your miss. Decel popping is unburnt fuel igniting in the hot pipes, so the hotter the pipes get, the more popping you have.
I recommend calling Fuel Moto and they will get you what you need. Just remember you usually get what you pay for, so I would not go too cheap on a fuel tuner.
socialoutcast
14
06-17-2021 07:23 AM
