Quick release backrest w/ "whole lotta shakin going on"
Just completed the attachment of a detachable sideplate/backrest on my 2012 WG and now have a "whole lotta shakin" going on behind me from the bike's natural vibration. Quick detach clamps are locked down snug on the rear frame rail studs but there is some minor play between the forward mounting studs on the frame rail and the c-shaped engagement on the side plates. I would have to think this is necessary in order to remove the side rails from the forward mounting studs. Anybody else experienced this and what have you done to reduce it?
Had the same problem on my Sportster, with brand new hardware no less. No noise when somebody riding b!tch or when you have some luggage. I tried bending the c-cutouts (sideways) a bit to make it tighter but did not help much. What worked best was to loosen the bolts on the sideplates and twist one down and the other up a bit... so it's not sitting flat when set on the floor. The slight offset would preload the attachment enough to prevent rattle.
I have the same Sissy bar and mine did rattle also. The electrical tape is the answer. All you need is about one wrap at all four docking points and it will stay rattle free until you remove it. I also went to lowes and bought some small rubber o-rings that you can streach over the front docking points and that works also. I cant stand feeling it rattle. You can trim up the tape with a razor blade and you want even see it.
