Passenger peg mounts 2014 FXDB
So I want put some mounts on, (only have pegs by them selves) and want to do it as cheap as possible. Was trying to find a thread on this with no luck. Though I might just be slow. If anyone has maybe a link to really cheap mounts and hardware, or maybe a how to fab yourself would be great! Thanks in advance
Can't help you there, but just an FYI, picked up a set of the stock mounts the other day for same bike (I had reward points from the dealer). If you do end up getting stock the instructions tell you to loosen the rear wheel and belt drive to make left side install easier, you don't have to do this.
Kuryakyn makes a mount that straightens the pegs so they aren't crooked, but they are made for Kuryakyn pegs and floorboards:
http://www.jpcycles.com/product/632-484
Here is what I used. I went to a local tool company and asked if I could go outside and check if the angled torx they had would fit (they wanted 11.99 for the damn thing). I went out and busted the belt guard loose (returned wrench) then went home and used the short bit to finish the job. I was worried about not giving it enough down pressure and stripping the head while trying to remove belt guard mount with the short bit
