Any electrical savvy riders help me out?
Hey guys. To start out, I have an 08 Street Bob. I let my ex roommate (while he was still a roomate) respray my bike, as it was getting faded. He got it all back together (or so I thought) and since then, I'm having some weird electrical problems.
When I turn it on, everything looks fine. When I fire her up, the center cluster goes out, the left front turn signal goes out, and my blinkers don't work. After I ride it for a few minutes, I turn it off, restart, and the center cluster will work and sometimes even the blinkers, though sometimes not. I replaced the left turn signal bulb, but it stopped working a few minutes later.. Weird part is, when the blinkers are actually working, it works too, but won't stay on.
I took my bike to a friend in a club, and we tried to trouble shoot. We pulled the seat and checked the wiring, even pulled fuses and cleaned them off. After all of that, left the seat off with wires exposed, and everything worked.. Turned her off didn't touch anything, started it back up, and then ran into the same frustrating problem. He have no clue, and his only guess is the fuse terminal?
Sorry for the long story, I've just been searching all over and can't find these symptoms, and wanted to check here before having to pony up money at HD. Thanks guys.
Somewhere I'm guessing you are getting shorted wired maybe got pinched somewhere. Would be an easy fix if that's it, also could be a nightmare finding the wire if it is too, or a connector somewhere got yanked on a little hard making a inconsistent connection. I hope it's not like computer related somehow
+1... look at the dash harness area for broken connectors/clips and also if that harness was "pulled", then it could have messed with your turn signal connectors inside the backbone towards the front of the bike. Multiple connectors in there.
Grounds
There are some grounds underneath the tank in the frame. These grounds coming loose will cause similar symptoms, so I would have a look at that too. Remove your tank bolts, slide the tank back and pull out the plastic "cover" that is there. The grounds are on the inner left hand side inside the frame.
