Touring rear turn signal bar on a SG.
Yup did it to mine, I didn't have to grind anything, I installed a street glide turn signal bar on mine, the tricky part is drilling the holes in the fender to mount it, because of the angle that the screws go in, also had to drill smaller holes for the wriring.then I used a large HD medallion to cover the old plate holder holes
This is the thread I used when I put one on my '07 FXD. Turned out great and was pretty easy, just go slow on the grinding and check the fit as you go. I definately recommend drilling holes in the fender for the wires to run too and put some grommets in there to stop the wires from rubbing. Don't forget to put some paint/protector on the exposed metal in the fender (from mounting holes) and on the back of the light bar. Hope this helps.
https://www.hdforums.com/forum/dyna-...turn-sigs.html
