Did I mess up gasket?
Pipes get here Wednesday, so I just put in new exhaust gaskets prepping. The back one gave me a little trouble putting in but it really doesn't look any different than the ones I took out, but wanted other opinions to see if you think I should get another new one.
It has a slight bump in it that I tried to smooth.
[IMG][/IMG]
[IMG][/IMG]
Don't think it's that bad, did about the same to mine as I was installing new pipes and worked out just fine. Just be careful not to catch the lip of the new pipes going into that otherwise might make it worse and then be a real problem.
Looks like you're running kind of lean though, white on the valve stem.
