Need help with turn signals
Hi everyone I'm new to the forum but have been reading posts on here for awhile.
I removed my rear fender strut covers so they could be powder coated. To do so I had to remove the rear blinkers. I would like to replace them with a set of fat black rear turn signals. I also have the hardware for quick release saddle bags. Does anyone know a good set of replacements that might work with existing hardware?
Do replacement turn signals have removable posts and I can just screw onto the extended post?
Thanks for all the help.
www.JokerMachine.com has a few options, they offer an extended bolt that the wire can pass thru. If you knock off the threaded part of the rear inner fender bracket of the detach kit, you could insert that bolt and use of of these lights.
Comment on a few more post oput there, you'll need five post before you'll be able to see the pics I believe.
The bolt they also offer
pheur
03-14-2012 01:26 PM
