just finished installs there led kit with the load equlizer with is a simple plug an play. everything works but the rear right side. i thought it was maybe a bad bulb from them so i switched the sides an still nothing. when the put a reg glass bulb in it works so i know the port on the bike is fine. any one have this problem or can help ? thx!!!
since there is power to the socket theres not much that can be wrong. the new "bulbs" arent making connection to one of the 2 terminals. normally this is the bottom one. try bending it out a bit.
My guess is you have something going on with the connector, seems just some playing around with it will fix it, though I can't see it but maybe a little pin of some sort is a little out of place inside the connector.
I had that problem but I didnt have a load equalizer, was taking a chance. Since you do have one, not sure what it could be besides maybe a defective load equalizer?
