Help me diagnose this sound coming from my primary
'13 FXDF, 7K miles: I have a low-frequency whine that correlates to vehicle speed(not engine speed) and is most noticeable when clutch is in and coasting to a stop. It sounds like wo-wo-wo-wo all the way down to full stop. It's harder to hear over the other engine and exhaust noises but it is there on acceleration as well, but it is much louder and lower speed. This is a new sound that started a few weeks ago and has since gotten louder and louder. It is worse when the engine is hot. This is also a few months after having the entire primary removed to install the Andrews 30t pulley and a Hayden M6 tensioner. If I'm gonna have to take it all apart again to replace a tranny bearing at 7K I'm gonna be ****in pissed!
There was a long thread over on the HTT Forum about the Hayden and how it keeps the primary chain too tight and for the OP it was causing a noise while riding and a "clunk" on shut down. He ended up pulling it out and installing the Baker manual tensioner and all the bad symptoms went away.
I am running the Hayden too and have my primary open right now. The primary chain is pretty fricken tight and I am sooo close to ordering the Baker myself.
The other possibility would be the compensator, but it correlates to engine speed.
Some things are best left alone until defective IMO
or " if it ain't broke fix it till it is"! - ha ha joke
Check if your drive belt lines up perfectly straight from rear wheel to pully.
Otherwise you will haave to have your outer primar off to check your other components.
On the bright side... that steel gasket and the bolts, heck even your oil can be re-used.
I don't understand why someone would turn away money.
If the Dealer turns away a 'warranty' problem, the bike owner is gonna be pissed and use anybody BUT the Dealer to fix it. And for everything else in the future.
If the Dealer ignores that the owner opened her up, then fixes the problem..... He bills the MoCo for the parts and labor and earns a customer for life.
Whatever. Just my $.02
But surely 600 miles of a chain being a little too tight shouldn't have damaged the bearings, right? I'm more worried that this is related to my pulley install, which would require removing the inner primary and even then I might not be able to tell what is causing it.
