SE Comp Sprocket
SE Comp Sprocket
Here we go,
Last year I bought a SE comp sprock to replace my oem one thinking it was a better unit, and at that time everyone on site here agreed it was. That unit became the stock sprocket for '11 + bikes. Now i'm reading about failure of said sprockets for lack of lube and the updated version is practically the same except they send you a plastic oil deflector to bathe the sprocket with oil as you ride.
The question in my mind is should they not supply these parts to owners with the previous version or put out a call back order on them? After all they have sold plenty of 11,12 and 13 bikes with the inferior units.
Been there, done that. They did at least give me 10% off and that's without a receipt. The "new" also has a needle bearing thrust washer and oil passage holes in it. Only time will tell if it's any better. Pretty sad of HD to let the consumer suffer due to their lack of caring. I mean really they didn't know it wouldn't get enough oil and it takes them years to "maybe" fix it with an oil deflector. BS.
I'll be looking for your reports on the BDL. I put in the SE comp back in 2011, then read about the problems with them. While I haven't had any issues I would rather get it out, and I don't have much confidence HD can come up with a decent comp design. I guess I could go back to my stock 07 comp if I had to, it's sitting on a shelf somewhere around here.
Hey maddghost, if you want to get more oil on your compensator install the CompenSaver tray that GMR sells. It is designed to work with the 2014 compensator but I asked one of the designers - Ron if it would help my 2012 version and he said yes although the outboard part of the compensator would still be lacking oil - that is where that glue in HD tray hits.
I am thinking about putting it in myself but it will not work if you have the Baker manual primary chain adjuster in which I am also thinking about.....decisions, decisions.
There is a review, read in.
https://www.hdforums.com/forum/showthread.php?t=938462
