Brake Bleeding issues
Hey guys ive been having a hell of a time getting my front caliper to bleed. I got a chrome 4 piston caliper to go along with my inverted front end since the stock one no longer will work. I got the caliper installed and tried using a vacuum pump to pull fluid in and then do the traditional bleed job with the stock screw. I was only able to get the brake to work if i pumped it a few time but as soon as i let go of the handle it would lose all pressure again. I tried a different master cylinder, same outcome. I installed speed bleeders, same outcome. I sent the brake back and they said there was nothing wrong and it would hold pressure all day on their bench. I got them to send me a new one, installed it and this time i did a reverse bleed, using a pumping and moving fluid from the caliper up. Same damn outcome. I thought before i took it in to the dealer i would see if anyone on here had any thoughts? Thanks in advance
ive done it the old school way where i fill the MC and pump til it has pressure and turn the screw, close and repeat, with the same out come, no bubbles from the fluid coming out. I even pumped it up and zip tied it and let it sit for hours and it never lost pressure until i release the handle then it instantly loses all pressure. thats what is so confusing about this one, the rear was no problem, and this doesn't act like an air issue (not spongy or little pressure)
Zip tie the brake lever overnight and tap the length of the brake line with the handle of a screwdriver several times before untying it. You may have a natural area where air hides along the line. I did this and it hot better but not perfect. After riding for a couple of hours all the bubbles must have vibrated up and out because my brake is rock solid now.
