Is Tuner Needed?
Is Tuner Needed?
I have a 2010 fatbob with rush slip ons and the screamin eagle big air breather. The dealer did the initial flash that they do when you first switch out your pipes but my question is, is it still necessary to go with a tuner like the SERT if all you have had done to the bike is the pipes and air breather? or is the initial flash the dealer did all that's necessary. I've been hearing different things and just want to know before I spend a bunch of money. If it won't hurt the bike by sticking with just the initial flash, then that's what I'm going to do but if it's going to be running to lean, then I've heard that it could damage the engine. Thanks for any info.
I have the Dealer Download, aftermarket pipes and a Stage I Air Cleaner.
You have the bigger AC.
So I would ask some people who are running the same or similar setup.
Mine runs fine. Pops a little bit, but I could not care less about that. Kinda like it.
Everybody's different.
When you buy a Harley, you have a Blank Canvass and you are the Artist.
Have fun.
1 Post
They dealer download should be fine for what you have done. But here is the fly in the ointment so to speak with a real tuner such as TTS , Sert or my favorite the power vision you be able to find more useable power in that motor because you be able to manipulate things that may make more power but not meet epa requirements that the factory download is bound too.
In the end it up to you. Keep the download and enjoy what you have (it's safe) Or do a custom tune and get what you really paid for out that motor. (fun)
