Yet Another Annoying Carb Question
Hey All,
I've been searching to forums and am having a difficult time finding the answer to my specific question so here it goes.
I'm getting really sick of the decel popping (I know a lot of guys like it, but not me) and i'm trying to find a way to tune the carb to get ride of it. I've heard and read that decel popping is typically a symptom of running too lean. So I'm trying to figure out what I need to do. I don't have too much experience with carbs but am trying to learn how to do most of this stuff myself. I don't know if theres any "typically changing to this size jet will do the trick" fix but i would appreciate any and all knowlage/suggestions/links to pages where someone has already answered this questions.
It will probably help to know its got a high flow intake and slip-ons (I have no idea what kind of slip-ons, they were on when i bought the bike and i can't seem to find any makers mark or stamp anywhere).
I'm not in a huge hurry to get it does, i'll probably save it for a winter project, but i'm trying to get all the info i can early.
Thanks!
Thanks!
CV Performance makes an excellent kit for CV carb rebuilds and provides some excellent documentation on jet sizes. Remember that altitude and driving habits play into the overall equation.
http://www.cv-performance.com/
They include a EZ mix screw for adjusting the idle mixture. I highly recommend that you leave that part of the rebuild alone unless you are very comfortable with working on your carb.
Ack! Save yer money & spend 12 bucks on a OEM '88 XL1200 needle & another 7 bucks for 46 pilot jet. Leave the main jet alone. Read up on pulling the cover plug off the idle mixture screw & setting your idle mixture & you'll be golden.
Decel popping gone, warms up quick, great throttle response at all rpms & 43-44 mpg.
The EZ idle mixture screw is a good idea tho & much easier than trying to get in there with a screwdriver while the engine's running.
ETA- at your altitude, the XL needle might be too rich. Alternatively, you could try shimming the needle. Good article on tuning the CV here- http://www.nightrider.com/biketech/hd_cv_mods.htm
Received 4,307 Likes
The higher the altitude the richer it will run! My FB runs really lean on the Oregon coast! Hell, it runs a tad lean here at 2540 feet! I do get rumbl-d-pop some here too! I have slips and stock intake! Plugs look good and runs cool so not concerned much! Just giving you some info that may be of use...good luck!
