Wheel fitment help
Wheel fitment help
here is my question ( ived searched but can not find out)
I have an 2011 super glide with stock laced wheels.
I just purchased mags (ten spoke) off an 09 super glide which i believe are the same as 2011 mags.
I know i need a diffrent front brake rotor but what else? Seems like i need diffrent spacers because mag hub seems wider. And can i pull the rear sprocket and rotor off the laced and put on the mag? Any help will be great
I just did that swap on my boys 2010 street bob. The bearings, outer spacers, rear rotor and pulley are the same part numbers. I cant remember if the bearing spacers in the hubs are the same, since we got new front and rear install kits when we put on the wheels. I might still have the info written down at home, I can post up here for you later. For the front brakes, you will need a new rotor, and the shoulder bolts and wave(spring) washers to install. If you google shop ronnies harley, the have an online parts micro fiche, where you can cross reference the part numbers. Oh, also make sure you replace the pulley bolts, they are a one time use deal.
two more question (i should own a manuel but i dont)-
1. in which direction does the spring/curved washers for the front rotor go? curve away from the rotor or curve towards the rotor?
2. in this diagram http://partsfinder.onlinemicrofiche....ST-AND-SLOTTED) it shows a spacer #6 in between the bearing and and the inner bearing spacer, that just doent seem right, any thoughts?
