DIY air ride done
ok... so a ride report... air ride in back so far is the best set up i have had (done progressive 12" 412, 11" progressive, V rod shocks, HD bagger air shocks 12, bagger HD 11 air shocks, stock shocks, and Burley slammers) the adjustable is unreal! can go from a low slammed look that is like floating on a cloud, to a lifted up firm ride for ripping turns.... Race tech emulators = really did well to smooth out the ride and made a dramatic improvement in handling response. I did progressive springs, dual top out, emulators, 130mm fluid, 5 turns, and 15w spectro.... storz steering damper = BAD ***, nothing else really needs to be said about this sucker, completely adjustable and helps plant the front end, thanks Justin Mcginnis for hooking it up.... Super brace = just rounds out the package up front. The bike feels like it can rip a super bike track up.... Brembo front brake = less than impressed. Took so much work to make this thing work on the bike, and of course customize the caliper itself and the difference is a touch better than stock, if not the same, if I could do it all over again i would leave the stock brake caliper, shave and coat that. I only have about 75 miles on the bike so far... but that is the ride report!
Question
Could this same thing be done minus compressor? I once had air shocks on an old pickup truck. They had a shrader valve to raise and lower. They never lost air. Just thinking it would be nice on the rare occasion the wife rides with me if I could add a little extra height.
I am not an expert but I don't see why not. Same theory as the FLH with air shocks. On those you adjust air as needed (i.e. adding weight, removing weight), not every ride. I had air shocks on a car way back when also, and I only put air in them once so they were where I wanted them, never touched them again.
Couple questions....
The "dump valve" just makes it go down faster?
I saw on another thread that you made a mount to go near the forward control mount, why did you not use it? I can't seem to find that thread.
I've got the shocks already, and the compressor is on it's way. Looking forward to getting this done!
