12' Dyna Wide Glide Tire's Bald Again
Hey guys, my neighbor and close friend owns a 2012 Dyna Wide Glide. He is 65 years old and a pretty conservative rider. He has 13k on his bike. And is going on his 3rd rear tire(It's BALD again). The 2nd front has some left. I believe he started off with the Michelin Scorchers 31. Then tried the Pirelli Dragons.
The stockers(Michelin's I believe) gave him 7k
The Pirelli Night Dragons gave him 6k
What in the world is going on to cause his tire's to wear so fast. I've read he isn't alone in this situation.
I have suggested going to the ME 880's or the ME 888's. I understand Metzler doesnt make 180/60B/ 17's. But some guys are getting these instead:
Front 100/90-19 M/C 57H TL ME 880
Rear 160/70 B17 M/CTL 73 H(D) ME 880
To my understanding changing the tire sizes will effect the speedo but should give closer to 10k per tire vs the 6-7k he is getting now.
Does anyone have any information they could share with me on tires. Kind of frusterating. As far as I know there are only 4 tires made for the wide glide rear. The Michelin's, the Pirelli's, and two Dunflops.
HELP
HELP
I guess the street bob does better for tires than the wide glide does. So that explains the 9k.
The wide glide has a special size rim. There are only a few tires that will work properly with the factory rim. I run a 1800 and got what was on sale. Then I noticed the tire appeared to have too much air. About 6,000+- on most of my tires. So instead of being restricted I went to a 170. Now my mileage is a lot better. I have 8,000 on my rear tire now and have a lot of thread left. What happens is most 180 series tires are too large for the rim and causes the center to be pushed upward. Lost of traction-if you notice it- and less mileage. It pushes the center out like a over inflated tire does but more so. Since going to a 170 series tires I am getting a lot better traction. How I tested my theory is I made it spin the tire on both the 180 and the 170. My tire mark was much wider on the 170 than the 180. Plus I could feet the difference in the traction. On a 180 it would spin all the way through 1st and most of the way in 2nd. Now it grabs much sooner.
just a thought.
just a thought.
just a thought.
just a thought.
I noticed Metzler makes this size 170/60R 17 Do you think that would be a good replacement? And how much would it effect the speedometer?
