Upgrading Brakes
Upgrading Brakes
I'm planning to upgrade the brakes on my 02 FXDWG. From the first trip home, I thought the brakes were pretty weak(came from Sport bikes). Clearly,since it was 13yrs ago it has been shuffled down the upgrade list.
I'm thinking about PM callipers with a softer pad. Or a composite Rotor (black,so cool!) and a softer pad and keep the stock callipers.
What do you think the best bang for the buck would be? I'd like to keep it around a grand so doing both mods cannot happen. If you have upgraded Brakes, what did you use and how satisfied are you? Thanks.
Up rated brakes
Here in England I used Beringer brakes.
They work absolutely fine - progressive when you need them with no sudden surprises. Superb when you need to grab a handful.
Check out a company in England called RocketBobs - Pete makes some superb parts & some tiny but excellent brakes
motorcyclist magazine Nov. 2013 >>MC garage section
they did a back to back brake pad change test on their long term 2012 switchback
changed the stock pads out for EBC double-h sintered at 15,000 miles and found on average that the new pads stopped the bike by 1/3 less distance. took them by surprise at what a huge difference those pads made!
DO NOT DO THIS! Junk *** upgrade! there is actually no upgrade going to a stock Brembo HD caliper, the pistons are the same size as your stock 4 piston, the brake is not designed by brembo, it is only built by them! it is not a true brembo! i Just did this on my bike and it is junk! even with braided lines... i was so un impressed i called brembo and the tech is the one that told me that it is a HD design just their build, he laughed when i said i was "upgrading" he said you mean lateral move not upgrade right! I can not wait to get this caliper off my bike!
I went to braided stainless brake lines & Lyndall pads on my stock front caliper. Blech. Still sucks. For reference, my last bike had dual 6-pot calipers with 13" Braketech floaters.
When I get the FLST front end built & go to a 16" front, I'm thinking hard about one of the differential bore Brembos with a 12.6" Braketech floater.
