Different rear turn sigs
Old 07-23-2014, 04:47 PM
adm's Avatar
adm
adm is offline
Received 2,460 Likes on 1,407 Posts
Originally Posted by Dragon354
I have Kellermans on the front with the under mirror mount. If you don't look for my lights you will never find them.
:-) Is that a testament to the styling or the brightness?
For several hundred bucks, I want LED turn signals to be really, really bright compared to stock. I want the cagers to see me when I am indicating.
Old 07-23-2014, 05:01 PM
Dragon354's Avatar
Dragon354
Dragon354 is offline
Both. I have the run turn on mine so I retained the running light. Cool part is that the running light is white so it matches my headlight and the turn is amber.
Old 07-23-2014, 05:02 PM
Dragon354's Avatar
Dragon354
They are soo bright they light up the forks on my bike.
Old 07-23-2014, 10:14 PM
Kustrud's Avatar
Kustrud
Kustrud is offline
I got the perfect solution for ya. These are stock signals, sprayed with bed liner, bought spacer and short bolt from hardware store and did away with the stem thing. Total was like $10. Then I added LED inserts which are super bright if ya wanna spend a little more. Blindingly bright with the LED's.
Old 07-24-2014, 06:18 AM
chickenhauler's Avatar
chickenhauler
chickenhauler is offline
Originally Posted by Reindeer
Custom Dynamics integrated taillamp with Joker Machine LED turn signals. I drilled small holes and mounted them directly to the fender.
Wow that looks sweet. I see you have detach's-- are they for bags? I have been looking for a way to keep mine & mount my detachable bags. I also have the CD integrated, but want separate signals & don't like any relocation kits I've seen. Jim
Old 07-24-2014, 07:01 AM
Jeff's 1st Harley's Avatar
Jeff's 1st Harley
Jeff's 1st Harley is offline
Man those are cool they disappear.
Old 07-24-2014, 07:32 AM
mikeg212001's Avatar
mikeg212001
mikeg212001 is offline
Originally Posted by Chadster21
these are nice!!!! how much did they run ya? much messing around on install?
The lights were $159 shipped, from alloy art, and the dual converters were $14 and some change shipped, from custom dynamics. All in for around $175.
Install was easy, just some basic wire splicing. I think the longest part was taking the old sigs off.
Old 07-24-2014, 07:35 AM
mikeg212001
Do you happen to have a pic of your fronts sigs? Sounds like something I want to do on mine.
Old 07-24-2014, 08:50 AM
Reindeer's Avatar
Reindeer
Reindeer is offline
I've got detachable saddlebags and sissy bar. When I bought the bike it had the HD relocate kit where the turn signals stuck way out from the license plate, not very clean. These fit in real nice, don't get in the way of the bags or the sissy bar. Since the bike and the lights are black, you can barely see them when they're not on.
Old 09-03-2014, 01:02 PM
ajk511's Avatar
ajk511
ajk511 is offline
Originally Posted by mikeg212001
Here you go! Alloy Arts, wired with custom dynamics dual converters, so they function as run/brake/turn. I probably should have more light on the back, but I guess its the risk i take to have the back of the bike lookin hella clean.
Are you running the HD quick detach kit as well?
grbrown
07-07-2018 04:36 AM
kmh54
01-11-2011 07:14 PM
Jhorra
03-25-2009 02:58 AM
Asphalt Cowboy
05-07-2008 05:30 AM
nampahcg
12-12-2007 10:01 AM
Quick Reply: Different rear turn sigs
