Replacement Bulb for 1156LL
Old 07-23-2014, 05:18 PM
jabanas1's Avatar
jabanas1
jabanas1 is offline
Default Replacement Bulb for 1156LL
I have a 2005 dyna superglide. I replaced the front turn signal bulbs with a 2357LL. I'm trying to find a brighter bulb for the rear to replace the 1156LL but I can't find a replacement. I've searched hear and elsewhere with no luck. Does anyone know? Thanks
Old 07-23-2014, 05:56 PM
Mikula's Avatar
Mikula
Mikula is offline
just buy an LED bulb. most 1156 will fit fine
Old 07-23-2014, 06:15 PM
jabanas1's Avatar
jabanas1
jabanas1 is offline
This may sound stupid but will the led bulb also be 1156?.
Old 07-23-2014, 06:21 PM
2002flstc's Avatar
2002flstc
2002flstc is offline
The LED will be a replacement for an 1156 you'll see when you go shopping... online or at the auto parts store.
Old 07-23-2014, 06:37 PM
jabanas1's Avatar
jabanas1
jabanas1 is offline
Thank You
Old 07-23-2014, 11:12 PM
slozomby's Avatar
slozomby
slozomby is offline
i might be wrong but isnt:
1156 is the rear bulb.
1157 is the front bulb ( since it is also a running light)
also when you switch to an LED you'll get fast blink unless you put a load resistor for pre-canbus models.
also the LL bulbs you bought are long life. and not as bright as other bulbs.
Old 07-24-2014, 11:32 AM
BigDogIdaho's Avatar
BigDogIdaho
BigDogIdaho is online now
I picked up the LED versions of the 1156 at my local parts house. I got them with red bulbs because I have smoked lenses on my Street Bob. They flashed fast for a minute then went to normal. The manager at said store put them on his Glide with the same results. I believe him, since he used to be my boss and I have seen his bike. You can pick up load eq's there if you need, but you may (probably) won't need to.
That being said the higher the # the brighter the bulb. I'm guessing your rear lights are also running lights, but I could be wrong.
Sierra977
General Topics/Tech Tips
02-13-2023 12:42 PM
Rusty Axle
Shovelhead
03-22-2018 12:52 PM
wildfire
09-16-2016 07:14 PM
Will Concho
05-05-2016 07:56 AM
paulies 07
03-13-2011 12:50 AM
Quick Reply: Replacement Bulb for 1156LL
