leaking timing cover
So I changed our my cam cover but used the old timing cover. And somehow I'm leaking oil from the bottom of the timing cover. Idk how that's possible considering that no gasket was required to timing cover. Please advise.
2003 fxdl
I have pictures. Do not know how to post them here tho
2003 fxdl
I wish I was talking about my derby cover. It would be an easy fix. But I'm baffled at what can cause a leaking timing cover.
2003 fxdl
2003 fxdl
I figured it out. Went to my local chopper shop. Hyvon in whittier. They were able to inform me that all cam covers are not equal. I have an 03. And put an earlier model cam cover on as a replacement for appearances. However the cover I installed has a window for wires that come thru for timing on earlier models. That window is causing the leak seeing as how my model doesn't require that window inside the cam cover for the said wires.
