HELP, FLD headlight assembly swap.
Just thinking out loud here...
You would need to pull the stock headlight/nacelle
purchase headlight bucket and mounting block/bracket
drill hole in upper or lower fork clamp, Fatboy is on the lower
Mount headlight on fork calmp
The headlight reflector, lens, and trim ring from the FLD might fit the fatboy bucket. If you want to cover the fork clamps and tubes you would need to get some fatboy fork tins and figure out how to mount them to the FLD fork clamps, assuming the fork tubes are the same distance apart.
