Leaky Primary Case?
Clean it all up remove all oil residue and then take a good long ride.When you get back grab a small mirror and a flash light and u should be able to see the trail.Thats a reason why I like to run a different color oil RED LINE Shockproof in the trans.That way you know if its a primary seal or trans seal.
Normally I do run Red Line in the tranny, just so happens this last time I put in something different.
I will post up what it turns out to be, but its going to be a couple weeks until I get back to Cali.
The shift shaft seal is a rubber seal that the shaft goes through, this shaft rotates for every shift you make, eventually wearing on the seal and lettting some trans oil out. If you have access to UV oil dye put an ounce in the tranny, go for a ride then hit it with a black light. If it glows then you know what cavity is leaking.
Showed the pics to my buddy here in P'cola; he is a former HD Mechanic (former by choice ) and he is thinking the shifter seal also. I am hoping that is the case, sounds like the cheaper of the two between that and the primary main seal.
Will post up what the problem actually was in a couple weeks
Hi,
When i had mine apart the shifter shaft seal was almost non-existent but not leaking,
Any oil drops/splatter on debris deflector? Have you checked transmission fluid to see if it is a bit down on the stick?
The problem with this type of leak is that the dealer will want to change everything at quite a cost when may not be required, main seal gets mentioned and may well be worst case but i reckon there just as many out there that are the inner bearing race walking outwards
Thanks
Mirrmu
Thanks
Mirrmu
Hi,
Thanks
Mirrmu
Thanks
Mirrmu
I get what you are saying about the dealer changing everything; I actually want to talk to my buddy some more and have him give me a list of what should be checked in order for the problem. Instead of the dealer just going labor happy and changing all kinds of stuff that may not need to be changed.
Over the winter I went after a leak that I thought was the primary but it was the oil pan seal. All the bolts had vibrated loose over 36k and the oil was seeping out the gasket and blowing all over making it difficult to find.
I finally decided to spend a few hours removing every oil pan bolt, thread locking and reinstalling them and leaving them kinda loose until I followed up with the proper tq sequence and tq spec. I'd say most all of these oil pan bolts were loose and some pretty damn loose.
I don't have a single drop of any oil anymore outside my bike.
