dynoed my Dyna
Old 07-26-2014, 01:57 PM
Turbospirites's Avatar
Turbospirites
Turbospirites is offline
Default dynoed my Dyna
I dyno my dyna for the hell of it it's a 2010 FXD 96 ci 1584cc python pipes power commander 5 and screaming eagle cone filter 28k miles it made 74.45 hp and 90.20 tourqe that is normal right? I thought it would be around 68 for a basicly stock 96 I'm thinking of the S&S 585 cam and see what it would do what would be a good cam on a 96ci Dyna?
Old 07-26-2014, 02:23 PM
slozomby's Avatar
slozomby
slozomby is offline
getting off the stock map helps a bunch
Old 07-26-2014, 03:19 PM
HD Bobber's Avatar
HD Bobber
HD Bobber is offline
S&S 585 cams need to have compression set to 10.5:1+. Stock 96" is 9.2:1, so that wouldn't fall under the category of just a bolt on cam job. Andrews 48's have been getting outstanding reviews for just cam installs.
Old 07-26-2014, 03:33 PM
Turbospirites
Thanks for the info!
Old 07-26-2014, 04:35 PM
Turbospirites
The only thing for performance I'll do to it would be that Andrews 48H cam and a tune then just leave it alone if I want to go faster I'll ride my Buell Firebolt XB12 lol!
Old 07-27-2014, 12:27 AM
Foxster's Avatar
Foxster
Foxster is offline
That's about tight for a stage-1 bike. You would get those numbers from a free-flowing air cleaner and pipes with or without the PC5.
Old 07-27-2014, 01:22 AM
stbob07's Avatar
stbob07
stbob07 is offline
Yep. I got 88 t. And 76 hp out of my dyna. Big sucker and Vance and Hines big radius with a PC 3
Old 07-27-2014, 07:06 AM
Jeff's 1st Harley's Avatar
Jeff's 1st Harley
Jeff's 1st Harley is offline
Those numbers are pretty close to mine when it was stage 1.
Old 07-27-2014, 08:58 AM
maddghost's Avatar
maddghost
maddghost is offline
74 & 90 / stage 1 bike that's about on the money. The 585 cam is not for you, as HDbobber said not only do you need to bump the compression to 10.5:1 ( which for that cam is bare minimum) You have to get Adjustable push rods and you would have to be sure the valves would not strike the piston head.
Andres 48 is a great choice and ,I could be wrong , the SE 204 cam is supposed to be a good kick in the pants.
Old 07-27-2014, 11:48 AM
Cascade's Avatar
Cascade
Cascade is offline
I got 78.7HP and 137Nm Din. Stage 1 with thunderheader and heavy breather.
Quick Reply: dynoed my Dyna
