I found a rogue connector..any ideas?
Old 07-28-2014, 10:55 AM
rubberfrog's Avatar
rubberfrog
rubberfrog is offline
Originally Posted by maddghost
First you will need to find an unsplit hymen!
That explains why it is unused on most bikes.
Old 07-28-2014, 08:55 PM
Deathtrap's Avatar
Deathtrap
Deathtrap is offline
Well, just was curious what it might be.
Zip tied it up out of sight.
Old 07-29-2014, 05:37 PM
missedem's Avatar
missedem
missedem is offline
could be a battery tender charging lead to hook up a battery tender to. Mine hangs down near the starter.
Old 07-30-2014, 06:03 AM
AliensilverFXDBI's Avatar
AliensilverFXDBI
AliensilverFXDBI is offline
When I bought my street Bob it had the Harley led relocated tag bracket on it. Looked like poop so I replaced it with a lay down bracket. Anyhow while removing it I found it was plugged in to a stock existing terminal under the seat. This could be the connector you speak of.
Old 07-30-2014, 03:17 PM
The Wizard's Avatar
The Wizard
The Wizard is offline
Default Connector for trickle charger/battery tender?
If it has 2 wires with one male (ground) and one female connector (12 VDC) with a matching rubber cover, it is for a battery tender. You can verify by using a volt meter to measure between the pins. It would be ~12 volts with motorcycle ignition turned off - Slightly higher with motor running (~14).
Old 07-30-2014, 03:42 PM
UltraRider260's Avatar
UltraRider260
UltraRider260 is offline
What he said ... ^^^^^
Old 07-31-2014, 10:10 PM
Deathtrap's Avatar
Deathtrap
No,its not battery tender pigtail. It is a 5 pin plug of which it has 4 wires connected to it.
babygorilla
2014+ Touring Models
17
05-08-2016 10:58 AM
triplj
11
07-20-2015 08:29 AM
creimard
02-19-2015 07:54 PM
sixty7flh
Shovelhead
13
04-12-2013 07:47 PM
Bumper_RK
EVO
50
01-11-2013 11:50 PM
Quick Reply: I found a rogue connector..any ideas?
