accidently drained tranny
Old 08-02-2014, 01:41 AM
apetterez's Avatar
apetterez
apetterez is offline
Default accidently drained tranny
If I accidently drained tranny how do I replace fluid?
Old 08-02-2014, 01:47 AM
ynots's Avatar
ynots
ynots is offline
Put the drain plug back in and pour a quart of formula+ (or whatever floats your boat) in the dip stick hole on top of the tranny case
Old 08-02-2014, 01:54 AM
apetterez's Avatar
apetterez
I only see one dip stick opening. Is it the same for tranny and motor oil?
Old 08-02-2014, 02:02 AM
ynots's Avatar
ynots
ynots is offline
Tranny fill is Red
Engine fill is Blue
Old 08-02-2014, 02:07 AM
clap's Avatar
clap
clap is offline
No 2 seperate openings. Both on the right side of the bike. Larger **** closest to the cylinders is oil dip stick and fill. Smaller one towards the rear of the bike about the same level as oil fill. It is the tranny fill and dip stick. It might even look like a large screw head with a straight slot or a allen head in in. Did you get a owners manual with the bike. It should have all locations for fill and drain in it.
Old 08-02-2014, 02:12 AM
ynots's Avatar
ynots
ynots is offline
the tranny fill/dip stick takes an allen wrench to remove it
Old 08-02-2014, 02:17 AM
Hero's Avatar
Hero
Hero is offline
Diagram Ynots posted shows locations clearly. Do you have the correct type of oil to refill it? I know it's a Roadglide, but some useful info in this youtube clip.
Old 08-02-2014, 02:36 AM
apetterez's Avatar
apetterez
Default What type of oil is needed to replace tranny fluid?
What type of fluid do I need?
Old 08-02-2014, 02:37 AM
apetterez's Avatar
apetterez
And how much oil? Checked hot or cold?
Old 08-02-2014, 03:49 AM
loopie's Avatar
loopie
loopie is offline
for **** sake get a book or at least look up you tube videos or leave **** alone
Quick Reply: accidently drained tranny
